01-18-2016, 02:00 PM
Reading Bug Reading Bug is offline
Hi all,
I'm looking to burn quite a number of both single and dual-layer DVD+Rs for a project and currently use an LG-GE24NU40 with my PC.
http://www.amazon.com/LG-GE24NU40-Su.../dp/B00C4401UO
I originally bought it to rip DVDs and CDs (the internal drive doesn't work too well) but would like to consider other options, if there are any, for burning. I looked at both Pioneer and Sony, but their external drives all seem to be slim now. The LG looks like the only full-sized external drive made today. I plan on using good media, so that won't be an issue, but should I go forward with the LG? I know it's not traditionally rated well, but I understand it's not as bad as it used to be. Thoughts?
01-18-2016, 06:15 PM
Is the "OEM bare drive" the internal drive only, or the enclosure version? If the latter, get it while it's available for under $50. It should burn good at 8x, maybe 12x. I have one of the internal sibling models, and it's a great reader, not too shabby for a burner.
Since there's only 2 left in stock (1 from each seller, one of them Amazon), act fast.
The following users thank lordsmurf for this useful post: Reading Bug (01-18-2016)
01-18-2016, 06:59 PM
It looks like "OEM" is how they identify it without the extra material. Either way, the model is an external drive only. And I already have it. Thanks LS!
Should I use an internal burner with an enclosure? Or an external burner? darthpotato94 Blank Media 1 09-06-2012 05:35 AM
Need a good external DVD burner to record videos Kenneth M Capture, Record, Transfer 13 04-28-2011 06:23 PM
External DVD burner recomendations MagnificentMarcus Blank Media 6 01-08-2008 01:20 PM
Recommendation - External Burner lordgoat666 Blank Media 3 09-20-2005 03:44 PM
