02-07-2016, 01:56 PM
Tafflad Tafflad is offline
Running w7 64 bit
Installed 32 bit Virtual Dub ... and been using it fine for past 3 years.
However all the codes I normally use are no longer showing, if I load a file and the select full processing ... I should see all my codecs (Huffy, Cedocia, Lagarith, HQX, X264vfw etc.)
All I see are:
I have removed VD and downloaded new version.
Removed the codecs .... downloaded new ones, and reinstalled ......... still the same.
Any help appreciated.
Welcome advice.
02-07-2016, 04:46 PM
Goldwingfahrer's Avatar
Remembered
ou have no image of the C: \ earlier Acronis True Image?
might help
sfc / scannow
Removed the codecs
This is not only bad special inexcusably
that you should never do.
Reinstalling Huffyuv and Lagarith
HQX is ... install Canopus [Grass Valley] also Edius or the Procoder or the back or the free Canopus Codec Pack HQX.
install over the old version installed.
Since the Canopus DV Codex and the HQ is reinstalled.
Cedocida you no longer need today.
On W7 here VDub running 1.9.11 + 1.10.4 32 bit
with VDub 1.10.4 64-bit without problems on the same PC
If you can connect with "sfc / scannow" then Window needs to be reinstalled.
I always do before a change to the system a complete image of C: \
So can sleep well
02-07-2016, 05:31 PM
Fixed it .... well so far looks like it.
Using the Nirsoft Installed Codec tool, I could simply disable & re-enable codecs without resorting to regedit.
There was a post on Doom9 I was pointed to for a similar issue and they found that vidc codecs were to blame.
I disabled all the vidc codecs and .... success all the expected codecs reappeared in VD.
(so they must have been installed correctly after all)
By a process of elimination found out that it was codec VIDC.RTV1 as soon as I disabled that .. all is fine (so far at least)
I have an MSI graphics card and this is an MSI afteburner codec, maybe it is faulty or it got installed it an update.
02-07-2016, 05:46 PM
Remembered
I'm here I can not English only in German Doom9 Forum Gleitz
here I need vcswap
The following users thank Goldwingfahrer for this useful post: PizzaTime (07-26-2023)
ATI All In Wonder Hacks, Drivers, Codecs and MMC admin Capture, Record, Transfer 229 03-02-2024 05:13 PM
Installed a codec pack, and it doesn't appear in VirtualDub? someonewhy Encode, Convert for discs 4 01-15-2013 11:18 PM
Just Installed Adobe Photoshop/Premiere Elements rocko Restore, Filter, Improve Quality 1 11-01-2012 11:21 AM
Installed Service Pack 3 (SP3) for Win XP Pro and lost dictionary! cyber-junkie Computers 3 07-19-2012 02:32 AM
What are the best codecs to install ? jrnyhead Videography: Cameras, TVs and Players 1 04-28-2004 03:40 AM
