05-01-2016, 06:50 AM
jnielsen jnielsen is offline
Dear Sirs
I occasionally need to play an NTSC tape ( converting for customers ).
Right now i use a PAL player with "NTSC playback, NTSC on PAL". However this cannot be captured directly by the capture card ( Hauppauge USB2 Live ) even though I set it to NTSC capture. It works if i run the signal through my Samsung combo DVD-recorder/VHS-player. But not in good quality.
I am looking for a real NTSC only player. It is difficult to find in Europe, and I cannot on Ebay search in US only, so not easy to locate on ebay from here, unless I know the exact model no. to search for.
I have seen the "buying guide" lists on this page. But it does not need to be high end models with TBC because they tend to be expensive (and sometimes very used). Super VHS would be nice, but not necessary. A basic model will be OK. The most important is few running hours and that it is as new as possible (after 2000 or later).
Could you recommend some basic late Panasonic og JVC NTSC models to look for on ebay?
Or maybe a place in Europe to buy a real NTSC player.
05-01-2016, 11:42 AM
Most JVC US models end with the letter U, I have a Toshiba VHS only that is true Multistandard, It doesn't convert between formats, that I will be selling but not now as I'm busy taking care of some stuff. The problem of buying from the US is the shipping is expensive. Where do you live I can help you with the search.
The following users thank latreche34 for this useful post: jnielsen (05-01-2016)
05-01-2016, 03:32 PM
I live in Denmark, I have tried to search the specific U models mentioned in the buying guide, but they are few and expensive. And from the PAL models in Europe I have experienced it is difficult to get a good high end model with TBC. Many seems to "circulate" on ebay, being worn out or having minor errors, or just beeing plain defect. Just bought two NV-HS1000 which I had to sell again as defect for 1/3 of the price.
"Plain" models is much easier to get in good shape. I cannot just search the "U" models, I can only search specific numbers which I do not know. I cannot limit the search to USA only to "world" if I want US included.
Search for "NTSC Videorecorder" only gives a lot from Europe that claims to be NTSC but is "NTSC on PAL" meaning not real NTSC.
This is why I am looking for a list of some of the newest NTSC models of Panasonic and JVC, also low end models without TBC and maybe even without Super VHS. Low running hours and young age is most important. Maybe I could even find one in Europe, saving some freight and import tax.
Toshiba true Multistandard could also be interesting, but I do not really need that because I allready have some good PAL units.
Just found this thread,
http://www.avsforum.com/forum/106-dv...hs-player.html
mentioning these models
Panasonic
PV-8664
PV-9660
PV-8451
PV-9455
JVC
HR-S5902U
HR-S5901U
HR-S5900U
HR-S4800U
But would still like to receive other suggestions
05-01-2016, 03:55 PM
set your capture card to pal60, maybe your software can't deal with that, try virtualdub or dscaler
The following users thank themaster1 for this useful post: jnielsen (05-01-2016)
05-01-2016, 04:10 PM
pal60? What? I had to read about it here
https://en.wikipedia.org/wiki/PAL
It seems that the "NTSC on PAL" VCR outputs a modified PAL signal called "Pal 60". This could be a good tip. I use Hauppauge USB Live 2 and Pinnacle 11 software, I will check tomorrow if I can capture in "Pal 60". Do you know if the result is just as good as using a "real" NTSC video player?
05-01-2016, 04:35 PM
Goldwingfahrer's Avatar
Remembered
Hello
In every country there are at least one of prof.Digitalisierer certainly more real NTSC recorder / Feeder possesses.
Since ask again.
I myself have 5 or 6 pieces, just once in German Doom9 forum daily.
Or visit my website.
Pinnacle 11 + 12 + 14 + 15 + 16 + 17 + 19 can begin with YUY2 or UYVY or Lagarith the UtVideo nothing.
Huffyuv_MT or Huffyuv can not will open in Pinnacle.
http://forum.slashcam.de/pinnacle-st...=pinnacle+yuy2
05-01-2016, 04:48 PM
Hi Goldwingfahrer
Thanks, but I do not really understand all this "YUY2" "UYVY" "Lagarith" "UtVideo" "Huffyuv" and other terms. And it seems hard to find an explanation in the internat that I understand. I just capture with Pinnacle in MPG2 and saves as DVD with Pinnacle or converts to deinterlaced MP4 with Handbrake.
What is you website?
It seems that just searching for one JVC "U" model on ebay brings up a lot of others. So I have found some interesting units. Seems to be many about 40-50 USD + shipping. But the idea of using a "NTSC on PAL" device for NTSC capture is still interesting, beacuse I allready have more of these units.
05-01-2016, 05:54 PM
As far as i could tell with my Jvc's vcrs pal60/ntsc results are the same. I did comparisons with an smpte bar from a commercial tape.
05-02-2016, 01:49 AM
Remembered
sorry ... Pinnacle is a disease that can only kompr. DV-AVI capture.
Mpeg2 encoder there are also better.
PAL-60 is to capture not a good idea, one needs to have true real NTSC recorder / or Fedder.
Panasonic AG 7750 [S-VHS]
Panasonic W1 / W2 / W3 or
Samsung SV5000
Samsung SV 7000
Samsung SV-300-W [S-VHS]
If a PAL movie to NTSC standards will changed ...
Avisynth [free]
Kramer SP-11D
www.ww-consulting.ch
The following users thank Goldwingfahrer for this useful post: jnielsen (05-02-2016)
05-02-2016, 08:51 AM
double post
Just bought this one
http://www.ebay.com/itm/121954412247
JVC VCR / VHS Video Cassette Recorder 4-Head HiFi Stereo HR-S3911U
Item price $55.00
incl. shipping and import tax 112 USD
Is it a good?
ntsc, ntsc capture, ntsc on pal
Basic hosting advice for hobby site? Good antispam filters? TheJoat Web Hosting 17 02-17-2015 06:21 PM
Recommend a good, cheap DVD player? Superstar Videography: Cameras, TVs and Players 8 07-17-2013 09:41 PM
Can you recommend a good Blu Ray or 3-D Blu Ray DVD player? lordsmurf Videography: Cameras, TVs and Players 0 12-11-2010 08:49 AM
Help need to get a good VCR S-VHS Player Konfusion Restore, Filter, Improve Quality 12 01-31-2008 03:08 AM
