09-14-2016, 08:48 AM
1 there is a problem with the media dvd disk if I print a cover dvd paper and put in black dvd case?
2 which imgburn configuration recommendations to make the best burn dvd?
09-15-2016, 03:40 AM
sengork sengork is offline
Did you finally get to the burning part of your saga? It's been a long journey...
1. No
2. For data disks I put mine Joilet+ISO9660+UDF (highest version). Also test verify your created disks as part of the burning process.
The following users thank sengork for this useful post: gamemaniaco (10-26-2016)
09-15-2016, 05:44 AM
1 Paper cover DVD will attract moisture into the case of black dvd and damage the media to dvd?
2 the ImgBurn has many settings and I look for the best settings and options to select to make the best burning in the media dvd
09-16-2016, 01:21 AM
1. No
2. In your case leave it at default settings as they'll be the most compatible combination.
09-16-2016, 05:34 AM
1 paper, any paper I print the dvd cover will not attract moisture and damage the DVD disc?
2 where is these settings that you mentioned? I did not find these settings imgburn to check the disc after burning and Joliet + ISO9660 + UDF
09-17-2016, 12:07 AM
1. No
2. Mode -> Build -> Options -> File System
Did you think of adding moisture absorber bags inside or around the case to mitigate the humidity factor?
09-17-2016, 06:10 AM
1 This setting is the best setting to perform the best disc burning Joliet + ISO9660 + UDF? what other options I choose for better burning?
2 I would like the opinion of lordsmurf and
dpalomaki paper cover dvd harm or not the optical disc
questions
Verbatim DVD-R 16X Inkjet Printable miclus Blank Media 3 08-28-2016 05:09 PM
Printing DVD covers - what is a good printer to get? admin Project Planning, Workflows 6 04-05-2010 03:47 AM
Scanner advise - for dvd covers manthing Project Planning, Workflows 12 03-15-2010 12:23 PM
Website with custom DVD covers? angelofanimes Project Planning, Workflows 4 01-23-2007 01:46 AM
1st Class Hub Printable media contrain Blank Media 1 01-07-2007 03:34 AM
