Closed Thread
10-31-2016, 09:24 PM
agcala agcala is offline
Hi. I've got an ATI Radeon All-in-Wonder X600 JMR-X600PRO-128-CO X600 Pro 128MB DDR PCI Express (PCIe) DVI/VGA.
I'm not interested in the TV tuner. I just only want a second display driver that works. My OS is Windows 7 x64 and I have got the latest drivers from AMD, namely 10-2_legacy_vista32-64_dd_ccc.exe. Any time I try to run anything fancy on the display which is connected to the card I get a BSOD due to some atikmdag.sys which seems to be unable to handle the chore. Not even a movie.
Is there a workaround?
10-31-2016, 11:53 PM
Have you tried the Omega drivers?
The following users thank lordsmurf for this useful post: agcala (11-03-2016)
11-01-2016, 07:16 AM
I have run a AIW X800XT on Windows 7 x64 without a problem. The Vista WDDM drivers work fine. The card will work under Windows 8 and 10 after disabling the "Fast Boot" function too.
If I recall, Windows Update will auto download the correct driver on 7. I would uninstall the driver obtained from AMD and let Windows Update have a shot at it.
Also, uninstall the Catalyst Control Panel. That seems to be a common cause of the crashing.
The following users thank NJRoadfan for this useful post: agcala (11-03-2016)
11-03-2016, 07:55 AM
Thank you very much for your reply! I haven't tried the Vista Drivers but Windows 7 installed its own WDDM drivers at the very beginning and the card continued crashing. It was only then that I tried the AMD drivers, to no avail. I do not use the Catalyst Control Panel so I never installed it, just the drivers. I followed lordsmurf's suggestions and installed the Omega drivers. I have just tried playing a couple of videos and so far it hasn't crashed. I will keep you informed.
Thank you very much for your reply! I followed the your suggestions and installed the Omega drivers. I have just tried playing a couple of videos and so far it hasn't crashed. I keep my fingers crossed though . The utility program that comes with the drivers wouldn't run on Windows 7 x64. I will keep you informed.
Closed Thread
Troubles with ATI drivers, crashing ATI MMC! Audio drivers? LFonseca Capture, Record, Transfer 4 05-03-2015 02:41 PM
Is the ATI All In Wonder x1900 card as good as the x600? cybergtooth Capture, Record, Transfer 1 02-17-2015 07:35 AM
ATI All In Wonder X600 vs. ATI TV Wonder HD 600 PCI? cybergtooth Capture, Record, Transfer 1 11-28-2014 07:18 PM
AMD ATI X600 Pro 256mb and ATI Media Center 8.7 Zoink187 Capture, Record, Transfer 11 02-25-2014 07:00 PM
Best drivers for ATI All In Wonder Radeon, Windows XP install? peter5on Capture, Record, Transfer 14 08-14-2012 01:51 PM
