01-21-2017, 12:59 PM
Ionmitchell Ionmitchell is offline
Hello, first post here. Thanks for the useful FAQs and stickies.
I'm able to capture my Video 8 tapes using a Canopus ADVC 100 (and may later add TBC AVT-8710) but I have had no luck finding a fast way to split the large files into smaller clips. I have tried optical recognition in both Scenalyzer Live and Premiere Elements 8. Since I have a large number (>40) of tapes to edit down, I could really use a simple workflow to help me scan and break the big .avi files into smaller clips.
If I have to do it manually, are there any tips for faster scanning/cutting of the unwanted footage? Any links to relevant posts would also be great.
Many thanks.
Ion
01-26-2017, 12:39 PM
Automated editing has never worked. Lots of software claims it -- always consumer (amateur) tools -- and none of it works. Editing is manual often-tedious task, the end, no way around it.
But 40 tapes is not a lot.
01-26-2017, 04:25 PM
Many thanks for that. I'm ready to roll up my sleeves and edit manually . I asked if I should be "breaking big .AVI files into smaller clips" because some of the files seem rather large e.g., a 3 hour Video 8 tape turned into a single 46 GB file. I thought editing such a large file could prove cumbersome. So now I'm thinking of splitting (manually) these large DV-AVI files into smaller segments, perhaps using Scenalyzer Live, before doing the final edits in Premiere. Is this a reasonable workflow or is there a better way to work with large captured files?
Thanks again
Ion
01-26-2017, 07:45 PM
It depends on your computer specifically the I/O for drives, but also RAM and CPU. I edit video on a Skylake i7-6700K with SSDs. A 46gb file would cause no issue for me. However, most video is 90 to 120 minutes, so 3 hours is a bit much. For logistics reasons, I would probably at least cut it in half.
Your workflow is reasonable, yes.
To cut already-AVI file, I'd skip Scenalyzer, and use VirtualDub with 'Direct stream copy' option. I feel it gives more control over the timeline.
The following users thank lordsmurf for this useful post: Ionmitchell (01-27-2017)
Ready to start capturing, any last minute suggestions? mnewxcv Capture, Record, Transfer 48 12-18-2015 12:07 PM
Best way to split audio from video Superstar Edit Video, Audio 4 07-21-2014 02:43 AM
How to repair PAR or RAR files, when split archives? manthing Computers 3 03-21-2011 07:45 AM
DVD+R vs DVD-R (chapter marks) admin Blank Media 2 05-15-2009 09:50 PM
