04-16-2006, 10:44 PM
manthing manthing is offline
all,
i've got an mpeg2 that i'm trying to author via dvdlab pro.
when i import the file into dvdlabpro, after demuxing, it moans about gop errors.
so i tried using videoredo to resave the mpeg2 whilst fixing the gop.
still dvdlabpro moans about gop errors.
really starting to tick me off as i've spent a couple of hours already.
any ideas how i can remove the gop errors?
or is it a dvdlabpro problem?
04-16-2006, 11:58 PM
DVD specs have a max GOP length and require sequence headers on each GOP. What is your source?
04-17-2006, 05:36 AM
the jvc drm100s. on fr185 mode.
in the end i've authored with the so called gop errors.
argh!
04-17-2006, 07:11 AM
DVDLab is quite honestly poorly written software, created by a guy that has a loose understanding of the DVD specs and has been known to plagiarize information for his site and software documentation. I'm really not surprised you're having issues.
All I can suggest is trying to make sure you have the most recent updates, check the third-party support forum that Mediachance uses, or better yet, upgrade to different software like Ulead DVD Workshop 2.
04-17-2006, 07:49 AM
okey-kokey lordy. will comply. over & out.
DVD probs MOTUfan Blank Media 11 12-19-2007 01:31 AM
Dvd copying speed probs. emokid Copy DVDs, Duplicate, Replicate 6 10-09-2005 11:25 AM
