05-03-2017, 10:01 AM
flaviotoribio flaviotoribio is offline
Hi guys! I was fixing the K mechanism of my AG-1980 and the MS (Mode Switch) just needed a little cleaning and the deck started working again. And the thing is, I couldn't open the MS entirely, so I just rotated it with some pressure to try and clean the contacts. But I saw some MS that can be opened so they can be cleaned properly, so I ask if any of you know if the VSS0365 (the MS being used on the AG-1980) can be opened too? I was afraid of it breaking while I tried to open it so I didn't go further with it.
Some images for reference:
Thanks!
05-03-2017, 10:32 AM
Quasipal Quasipal is offline
No, they can't be opened and resealed. What I do is as follows:
Remove (as you have done)
Saturate with 100% De-Oxit and leave for a few hours
Rotate the switch back and forth and then blast out the excess with canned air
Wipe the switch over and re-install
The De-Oxit is kind to plastic and will keep the inside tarnish free.
Make sure you reference the mechanism and switch points before removing though!
The following users thank Quasipal for this useful post: flaviotoribio (05-03-2017)
05-03-2017, 11:12 AM
Just as I thought. Thank you!
k-mechanism, mode switch, panasonic ag-1980
Panasonic AG-1980 capacitor repair? Argalby Video Hardware Repair 132 04-06-2020 12:26 PM
Panasonic AG-1980 VCR repair - Which boards to recap? dpalomaki Video Hardware Repair 3 02-17-2015 07:21 PM
More Panasonic AG-1980 Capacitor Repair Questions dpalomaki Video Hardware Repair 2 03-04-2014 02:24 PM
Panasonic AG-1980 VCR Repair in Southern California? jamp Capture, Record, Transfer 2 12-28-2013 03:03 PM
AG-1980 B&W / color switch weird issue volksjager Capture, Record, Transfer 2 02-18-2012 03:13 PM
