10-19-2017, 10:30 AM
render9 render9 is offline
Hello,
First of all, thank you guys for all valuable information and advice you post on this forum.
Currently I’m stuck with the issue of synchronizing the equipment during video capture.
My capture device is Blackmagic Ultrastudio 4K that has a Reference In, TBC DPS-235 with Genlock In, and VCR Panasonic AG-1980 without any sync ins or outs.
My question is – do I need to synchronize all this equipment, at all? Does it make sense to use external Sync Generator (like the one from Blackmagic that has several Sync outs) to send Black burst to capturing device via Ref in, and TBC via Genlock in, and to VCR (probably via linear or video in)?
I would appreciate your explanation on this matter.
10-20-2017, 09:28 AM
There is no need to genlock the equipment for capture. These inputs are required in professional video production studios, the typical capture workflow doesn't require them at all.
The following users thank NJRoadfan for this useful post: render9 (10-26-2017)
10-20-2017, 12:25 PM
Thank you for the reply! I was just confused by recommendations of some users on different forums who suggest synchronizing VCR with capture device.
10-20-2017, 07:14 PM
You have to be careful about online advice. Sometimes the people writing stuff know nore more than yourself, and sometimes even less (yikes!).
Genlock is for studios.
You just need an external frame-sync TBC, and preferably a line TBC in S-VHS deck as well. Use both. Former cleans the signal, latter cleans the image.
Also a word of warning:
Blackmagic equipment is known to be extremely bad on analog SD material. The SD aspect of the card is an afterthought. For example, BM is known to not report dropped frames. Why it even drops them is an unknown, as a cheap $50-100 range USB2 card can have no drops. Beware!
Quite a few reports of this problem in this forum.
The following users thank lordsmurf for this useful post: render9 (10-26-2017)
genlock, reference, sync
Maximum/Highest Quality Signal Transmittable Over S-Video? mrmuy97 Capture, Record, Transfer 18 02-27-2022 08:38 PM
All of a sudden, I get no video signal? jobeis Capture, Record, Transfer 2 01-09-2017 02:11 PM
No Signal in WinTV with s-video on Windows 7? Hampton80 Capture, Record, Transfer 1 07-26-2014 07:13 AM
Do I lose PQ advantage switching signal from s-video to RCA in signal path ? Mejnour Project Planning, Workflows 4 02-01-2012 05:12 AM
Is it possible to capture component video signal Mejnour Capture, Record, Transfer 5 01-24-2012 07:27 PM
