01-04-2018, 03:04 PM
TIGER8855 TIGER8855 is offline
So I have some video that have recorded at 1080/50p on my JVC camcorder that I want to encode using TMPGenc Video Mastering Works 5 and then author in Encore to Blu-ray disc.
Because Blu-ray doesn't support 1920x1080 50fps progressive, I'm not sure what settings to use in TMPGenc. Do I select 1920x1080, interlace and 25fps? Or am I better of with 1280x720, progressive and 50fps?
01-05-2018, 02:19 PM
TMPGEnc doesn't interlace well and wasn't really designed for that kind of work. Better to re-encode the 1920x1080/50p as 1280x720/50p, which is BluRay compatible.
The following users thank sanlyn for this useful post: lordsmurf (02-04-2018), TIGER8855 (01-05-2018)
01-05-2018, 03:49 PM
Thanks for the response. So, in future am I better off recording @ 1080/50i?
01-05-2018, 04:10 PM
If you want authentic BluRay, yes. Also, a lot of players and devices will choke on 1080/p50.
BluRay format specs: https://www.videohelp.com/hd#tech
Degraded shaky VHS-C source, how to transfer it? DeeSeven Restore, Filter, Improve Quality 3 02-08-2018 09:00 PM
Do you keep your source material after capture? premiumcapture General Discussion 6 06-15-2014 07:39 AM
Source file in sync - Output File completely out of sync? DeeSeven Encode, Convert for streaming 3 07-25-2013 10:58 PM
1080 upconvert player with DVD+-R Playback AbbeyRoad1969 Videography: Cameras, TVs and Players 3 03-04-2011 05:07 PM
How to convert DVD (from VHS source) for sharing online? BlazingSpeed Encode, Convert for streaming 1 12-14-2010 02:24 AM
