07-04-2006, 11:48 PM
d.smyth d.smyth is offline
does anyone know a program i can use to convert vlc files to dvd format.
thanks
07-05-2006, 12:50 AM
markatisu markatisu is offline
VLC is not a file format it is a media player (VideoLan Client).
If you have a VLC file its most likely a playlist or a stream that was saved in VLC Media Player and then its not going to be convertable most times.
My suggestion would be to go to the VLC homepage and ask in the forums, but whatever VLC file you have its not standard so it may take more work then its worth depending on the codecs or format it was originally in.
What are ZIP and RAR files? + How to use them admin Computers 4 03-12-2013 03:27 AM
Digital cable = the new svcd format Tranzor Videography: Cameras, TVs and Players 5 07-06-2008 05:19 PM
Converting Mpeg files to Avi files?? MagnificentMarcus Encode, Convert for discs 2 02-24-2008 06:18 AM
Format problem MagnificentMarcus Encode, Convert for discs 7 08-24-2006 08:10 AM
How to convert a Quicktime file to DVD format ? d.smyth Encode, Convert for discs 1 03-25-2006 03:14 AM
