12-02-2018, 02:19 PM
The ATI USB2.0 N (dongle) from 2005 [Theater 200 chip] is supported on Apple Mac OSX - EyeTV. I have a copy of EyeTV 3 on a Mac Mini running 10.6.8, so I plugged it in. EyeTV threw open a window with the output from the USB2.0 N
It supports Tuner, S-Video or Composite for NTSC, PAL and SECAM.
Recording presets are:
Video CD
589 MB per hour
352x240 29.97 fps 1.15 Mbps CBR, IBP frames
Audio 44.1 kHz, 224 kbps
Standard (DVD 120 min)
1.8 GB per hour DVD-compliant MPEG-2
Video: 352x480, 29.97 fps, 4.0 Mbps VBR (6.0 Mbps max), I frames only
Audio: 48 kHz, 224 kbps
High (DVD 90 min)
2.7 GB per hour DVD-compliant MPEG-2
Video: 720x480, 29.97 fps, 6.0 Mbps VBS (8.0 Mbps max), I frame only
Audio: 48.0 kHz, 384 kbps
I would rather capture without compression, does anyone have any ideas how to do that?
Screen caps attached.
12-02-2018, 03:59 PM
Oh, man ... it figures ... my Mac is down right now.
I need to test this ASAP.
What sort of default compression is it applying?
Do you have an extra copy of EyeTV3? I don't think I have it anymore, no Elgato cards.
In fact, I didn't know you used Mac. I may have a favor to ask.
12-02-2018, 05:21 PM
MediaInfo Data Display info is attached as a separate txt file.
Here is a download location for the version used.
Download eyetv 3 Version 3.6.9 (7524) HEVC
Sure, anytime
General
Complete name : C:\0000000021b46dca.mpg
Format : MPEG-TS
File size : 48.2 MiB
Duration : 57 s 190 ms
Overall bit rate mode : Variable
Overall bit rate : 6 727 kb/s
FileExtension_Invalid : ts m2t m2s m4t m4s tmf ts tp trp ty
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : No
Format settings, Matrix : Default
Format settings, GOP : N=1
Format settings, picture structure : Frame
Codec ID : 2
Duration : 57 s 224 ms
Bit rate mode : Variable
Bit rate : 6 007 kb/s
Maximum bit rate : 8 000 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 (30000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.580
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
Stream size : 41.0 MiB (85%)
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 57 s 207 ms
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 41.667 FPS (1152 SPF)
Stream size : 2.62 MiB (5%)
12-10-2018, 02:44 PM
Elgato brochure for the (NTSC) EyeTV Wonder USB 2.0
Elgato brochure for the (PAL/SECAM) EyeTV Wonder USB 2.0
12-10-2018, 10:25 PM
Thanks for attaching those.
04-08-2024, 09:50 PM
Sorry to resurrect a really old thread but was there ever a solution to capturing uncompressed with the ATI USB2.0 on a Mac (High Sierra)? Thanks
