01-21-2019, 03:00 PM
Micheal81 Micheal81 is offline
I have a HP 22CWA monitor. I know it's not ideal, but I'm trying to get it calibrated "good enough" without buying calibration hardware. I will use test patterns like found on http://www.lagom.nl/lcd-test/
I have a EVGA GTX 1070 graphics card. Do I use the graphics card settings or do I use the monitor's settings? A combination? My graphics card settings have a section where you can set dynamic range and color format or you can use default settings.
I also found a site the tested the monitor and has an icc profile. https://www.rtings.com/monitor/revie...pavilion-22cwa
01-21-2019, 03:45 PM
Both.
set dynamic range
Rarely good, boosts levels, fake color.
May help, may not.
01-21-2019, 04:23 PM
The defaults should be ok, unless you notice lack of contrast in very dark and bright areas. Computer monitors will normally use full range (0-255) RGB, other options are more for using with TVs.
01-21-2019, 04:36 PM
Both.
May help, may not.
So I first leave the graphics card settings on defaults, adjust with the monitor settings, then tweak with the graphics card settings?
Viewsonic VP2365wb/LED: Does monitor response matter for video capture? Mejnour Project Planning, Workflows 3 02-12-2018 07:13 AM
Calibrating a capture card to a video game console? (IRE) Zerowalker Capture, Record, Transfer 20 08-24-2014 09:58 AM
Best video monitor! 42" LCD TV vs small computer monitor? rocko Project Planning, Workflows 1 07-29-2014 07:35 AM
Advice for calibrating a broadcast monitor Mejnour Capture, Record, Transfer 3 07-26-2014 09:25 AM
Color calibrating your monitor? (Seeing "true" color of your video captures) baywatch242000 Project Planning, Workflows 4 04-09-2014 01:30 PM
