04-22-2019, 10:20 PM
ofesad ofesad is offline
I was checking some captures and doing the deinterlacing (Interpolate with yadif + Double frame rate Top field).
But I noticed that it had some noise at the bottom of the Top Fields.
And Bottom Fields seem quite nice:
I was wondering what reason could cause this noise and how I could fix it.
As is, I would change the Double frame rate Top field to Keep Bottom field and interpolate / discard top field.... but maybe there's a better way.
Thank you all for your help and comments!
Ofesad
04-24-2019, 01:39 AM
It could be the filter. I run into things like this in Avisynth from time to time. I saw one earlier tonidht, from an anti-alias filter. DAA was causing a rainbow line at bottom, so I switched the santiag(), and issue was resolved.
Editing interlaced footage without destroying fields? JamieStar99 Edit Video, Audio 3 02-23-2018 03:17 PM
Diagonal line noise on VHS video? Luma noise? bilditup1 Capture, Record, Transfer 66 10-17-2015 01:03 AM
Hi8 Capture - Noise/Interference at bottom of frame mbaya Capture, Record, Transfer 6 09-17-2012 06:54 PM
Unfolding fields before applying Virtualdub filters unclescoob Restore, Filter, Improve Quality 10 10-02-2011 09:18 PM
How to remove black bar from top/bottom of video (widesceen in fullscreen) bdreza Edit Video, Audio 14 01-08-2011 03:21 AM
