Anyone serviced a DataVideo TBC-1000?
2 Attachment(s)
I have a TBC-1000 which has been sitting idle for years. I inspected the internals before powering it on again and noticed the caps on the 'power board' are swollen and one of them leaking from the bottom:
Has anyone replaced the caps? If so assume a like for like replacement is sufficient for the two swollen caps which are: 10mm diameter 16mm height 5mm lead width 1000uf 25v 105C None of the other caps on the unit look swollen, just the power board ones, but wondering if anyone here has had to replace other parts in order to keep the unit within spec? |
First post updated. :congrats: |
Just go to digikey or mouser and select your capacitors from the selection menu, It's a super easy job.
Once the unit is repaired is there anyway to test the TBC to ensure it is working as intended?
