10-08-2020, 03:28 PM
duurdarzan duurdarzan is offline
Hi all,
I have several JVC HR-S9911U units and a JVC LP 20465-015 remote (bought separately). Unfortunately, I can't seem to get the VCRs to respond to the remote.
Video: https://photos.app.goo.gl/5PVkgHzsbcGrvpPM8
The remote appears to be working fine (I see the IR emitter flashing through my cellphone camera).
A couple of months ago (before I got the remote), I was able to at least turn them on or off using an IR blaster with my phone, but now the VCRs are not responding to the IR blaster either.
The VCRs had been turned off for a while. They function just fine without the remote, but I would like to be able to access the menu (which I can only do with the remote).
Any ideas on how to get them to respond to the remote (or the IR blaster).
Thank you for any advice
10-08-2020, 03:40 PM
It seems you've already removed the variable of simply having a bad remote. That leaves the IR sensor is blocked, dirty, or bad. Blocked or dirty is simply, dismantle the front plate of unit. Bad would require replacing, which involves soldering. But I've also seen where the IR going out is part of a larger board problem.
10-13-2020, 10:17 AM
I cleaned out he IR sensor head and there was no improvement either with the remote or an IR blaster.
I'd be surprised if the IR sensors on all of the VCRs (I have 5 of the same model) stopped working simultaneously (given they responded to an IR blaster a couple months ago).
I'll try replacing one of the sensors and see if that is the issue.
JVC HR-S9911U and Panasonic DMR-ES15 remote for sale [SOLD] history1 Marketplace 5 01-04-2015 08:35 AM
JVC HR-6600U buttons not responding gpot97 Video Hardware Repair 2 02-25-2014 07:10 PM
Adobe Media Encoder CS3 not responding tgjasper Encode, Convert for discs 4 10-10-2012 03:20 PM
For Sale: JVC HR-S9911U S-VHS VCR [DONE] quink Marketplace 7 08-23-2012 11:33 AM
