11-28-2020, 10:09 AM
ho3298 ho3298 is offline
I acquired a JVC HM-DH3000U today. It played VHS tapes smoothly. But when it played D-theatre movie tape, there was no image and sound (maybe black and distorted image sometimes). Even though I tried forwarding or rewinding the tape, as well as cleaning the head, no image or sound showed up.
Is it the problem of the tape or the machine itself?
11-28-2020, 11:27 AM
Check the user manual, D-Theater may not be available via SD outputs or may not play D-theater tapes at all, Are you using HD component?
Edit: You model does not appear to playback D-Theater movies according to this page:
https://www.us.jvc.com/archive/video/digitalvhsvcrs/
11-28-2020, 12:28 PM
I did use the HD component. But it just doesn't play the tape. The screen remains black when playing the tape.
11-28-2020, 05:08 PM
As I said above, your model does not have D-Theater feature, It can only playback D-VHS tapes recorded from an ATSC tuner programs. It can however playback high bitrate D-VHS tapes recorded using D-VHS tool thru firewire and the file has to be prepared in PC using a specific script.
11-28-2020, 08:06 PM
Well, latreche34, I think you should double-check the specs of my HM-DH30000U. The website which you provide says my machine supports "D-Theater compliant with the advanced D-VHS security system".
Can you please give me other useful advice, especially after reading the specs and user manual of my machine?
11-28-2020, 08:19 PM
Which page of the manual talks about D-Theater? I can't find it, But JVC is listing it as 30000 not 3000 maybe that's the difference although I don't think 3000 ever existed.
If your VCR has the D-Theater logo on the front panel it could be an electronic malfunction, possible leaky caps in the power supply that powers up the D-Theater decoding chip.
11-28-2020, 08:43 PM
May I ask which caps in the power supply I should replace?
Maybe I should have them replaced whether they are leaky or not just to be safe.
11-28-2020, 09:00 PM
I don't know, You need a service manual and some test equipment and follow the test procedures. You can still take it a part and look around the power section and check for any leaks or bad smell, Though caps can fail without leaking or smelling.
11-30-2020, 07:17 AM
I managed to capture a few photos of the distorted image when playing a d-theater tape. Can anyone please tell me whether this is the problem of the tape or the circuit board or something else?
11-30-2020, 02:00 PM
AVS forum have a lot of members who own D-VHS decks and threads about this issue.
Sony DCR-TRV330(PAL) no image/sound when playing tapes? hodgey Video Hardware Repair 4 02-12-2018 11:22 AM
JVC DH3000U analog video distortion? MetallicaManX Video Hardware Repair 8 05-09-2015 06:44 PM
JVC HM-DH3000U D-VHS VCR has unstable audio on analog inputs? Jpass992 Video Hardware Repair 1 08-11-2012 10:03 PM
Where to Buy Home Theatre PCs (HTPC) & Media Centers admin Videography: Cameras, TVs and Players 0 03-17-2009 02:47 AM
ATI chips: Difference between Theatre 100 and 200 chipset? Sujit Capture, Record, Transfer 3 05-06-2005 09:05 PM
