10-27-2020, 01:28 PM
dllep90 dllep90 is offline
Help! I'm getting an "er 09", and can't eject the tape. Anyone know what i can do?
10-27-2020, 01:40 PM
Look for the service manual, I'm pretty sure there is a copy right in this forum.
10-27-2020, 02:07 PM
Here: http://www.digitalfaq.com/forum/vcr-...html#post22645
10-27-2020, 03:47 PM
Thank you. I found the instructions to manually remove the tape which i did, but the error code still shows.
Attached is the image with the error info. I'm getting the sub-code 821, but i see no explanation of "possible failure" (unless the possibilities are the same as the ones given for sub-code 221?) or any advice later on in the manual as to how to fix it.
Does this mean i need to give it in to service (where??)? Is it a goner?
10-27-2020, 05:29 PM
Sorry i just learned how to properly attach images. Here it is
10-27-2020, 10:50 PM
It indicates a mechanical failure in the threading sequence, It could be a dirty mode switch or broken cam gear, If you have no clue about what I said that means it's a goner.
10-28-2020, 11:46 AM
I see... Are there no people who repair these things?
How to re-spool stuck tape in AG-1980P? lordsmurf Video Hardware Repair 11 11-20-2020 08:49 AM
Aiwa HV-MX100 tape stuck? darko886 Video Hardware Repair 4 06-14-2020 05:53 AM
Tape Stuck in Beta player ragu0012 Video Hardware Repair 2 06-08-2017 08:59 AM
Hi8 Tape stuck - Is there any way to fix this? DeeSeven Capture, Record, Transfer 5 04-23-2014 04:42 PM
