01-15-2021, 09:02 PM
doowteelf doowteelf is offline
I picked up this circa 1986 Unit and would like to get it going. I have cleaned the tape path and replaced the long reel belt, capstan belt and the belt that goes from the take up reel to the white pulley.
The cassette will load and gets pulled into place but stops after 2-3 seconds. Everything seems to function properly until it shuts down. Fast forward and rewind work fine.
Under the take up reel there is one sensor that I cleaned so far.
Is this problem a tape sensor issue or something else?
I attached a few pics. When I opened this thing up the metal plate that holds down the flywheel was missing...wth!
Is this a common mech that I should be able to find the metal plate on a donor unit..perhaps Panasonic or Hitachi?
File Type: jpg 621513C8-94AC-44B2-B17F-B0AE407E7263.jpg (91.5 KB, 5 downloads)
File Type: jpg 641EB148-F209-4325-AD87-AD6D973730E7.jpg (101.0 KB, 3 downloads)
File Type: jpg A688FB09-8A97-4546-BB53-BFD74B1AA713.jpg (170.0 KB, 3 downloads)
01-16-2021, 09:22 AM
Playing with this again this morning. I put a longer/thinner belt on the take up reel and I have it playing tape now with colours and sound on an old 13 inch TV for testing...lol always like the Lion King. The belt I had on it was tight.
There is a sensor under that take up reel so I am thinking this might be what is shutting it down. Perhaps the reel was slowing with the tighter belt?
File Type: jpg EB503A47-966A-464E-A6A4-ABC9E4F38D81.jpg (206.9 KB, 1 downloads)
JVC HR-S7600AM keeps shutting down after 3 seconds? Blackout Video Hardware Repair 124 12-28-2021 01:55 PM
Tape goes blue every few seconds? octodigitus Capture, Record, Transfer 17 06-17-2021 01:37 AM
VHS player stops playing after 1-2 seconds? birdmars08 Video Hardware Repair 2 12-04-2020 09:41 PM
Sony SL-F1 Betamax stops playing after 2 seconds? TONYFRANCE Video Hardware Repair 1 06-25-2018 11:38 AM
One VCR plays at wrong speed, other VCR plays for half second then stops Member-X Capture, Record, Transfer 5 02-12-2012 12:54 PM
