08-01-2021, 01:58 AM
Tokyo_DIY Tokyo_DIY is offline
Originally Posted by timtape View Post
Important also to work out what caused the gears to fail. Otherwise the new gears may fail in the same way.
Right.
One of the things I am wondering about is this black grease that has been used in this part of the deck. I have heard that the wrong type of grease (e.g. grease made for metal gears) can lead to abnormal wear of plastic gears.
I also do not know if that grease was used in the factory during original manufacturing or if the deck was improperly serviced in the past.
08-01-2021, 08:17 AM
Originally Posted by Tokyo_DIY View Post
In Japan there are plenty of old vcrs that you can buy for the equivalent of 5 ~ 15USD, so let me check a bit among used/junk stuff.
Yeah it should be possible to find vcr with the same mech for not too much, it was used in most Panasonic VCRs (other than in the US) in the late 90s and early 2000s.
08-01-2021, 12:14 PM
Dougmc Dougmc is offline
Lubricating it thru it's life would of help.but I think it's
Just a poor design the metal teeth gear against the nylon.
When it's fully loaded theres pressure against it from the tension
Spring. If the metal gear was twice as thick would of help
08-02-2021, 08:42 AM
When I add grease to vcr gears where at least one of the two gears is made of plastic, lately I use a silicon-based white grease with teflon. I hope this is ok. The drawback of this grease is that one 50g tube costs more than 1400JPY (about 13 USD).
National Panasonic NV-7500 VCR will not play? mobilechat143 Video Hardware Repair 5 10-20-2020 09:06 AM
Can't play S-VHS in Panasonic AG-6750? Jimartist Capture, Record, Transfer 2 02-01-2019 11:08 AM
Toshiba DX800 won't play, just makes horrible noise DeeSeven Video Hardware Repair 2 02-17-2013 04:40 AM
Panasonic FS100 S-VHS recorder won't play S-VHS tapes? via Email or PM Video Hardware Repair 4 08-19-2012 10:00 AM
Panasonic AG-5710 (AG-1980) can play VHS-C as 16x9? Jpass992 Capture, Record, Transfer 1 08-05-2012 11:39 AM
