11-10-2021, 11:40 AM
RS456 RS456 is offline
Recently one of my tapes got stuck in my AG1980 suddenly. I opened the cover and found the the tape got jammed in the VCR so I wound the tape manually to the point it is easily removable but VCR is stuck in play position and I can't seem to get the tape out. How to I manually remove the tape from my VCR and how to a manually get the AG1980 out of play mode?
11-10-2021, 12:56 PM
UPDATE:
I got the tape out finally and the VCR seems to be playing fine now. Is there anything I should be aware of since this happened? What should I do to prevent it from happening in the future?
11-11-2021, 09:38 AM
Good to read you got it out.
See response to your other thread.
For your and others future reference.
https://www.tgrantphoto.com/sales/in...stuck-vhs-tape
Sony SVO-5800 tape is stuck? dllep90 Video Hardware Repair 6 10-28-2020 11:46 AM
Aiwa HV-MX100 tape stuck? darko886 Video Hardware Repair 4 06-14-2020 05:53 AM
Tape Stuck in Beta player ragu0012 Video Hardware Repair 2 06-08-2017 08:59 AM
Hi8 Tape stuck - Is there any way to fix this? DeeSeven Capture, Record, Transfer 5 04-23-2014 04:42 PM
