04-11-2021, 04:42 AM
videoconverter11 videoconverter11 is offline
My JVC HR-S7800U VCR has a peculiar issue in that sometimes it works, and sometimes it doesn't. When it doesn't work, I put a VHS tape into the VCR and it will run for a few seconds, then ejects. On top of that, I heard a grinding/screeching sound.
When it doesn't work, I notice the loading motor belt was not really moving, and so moved it along using my finger. This seemed to do the trick for the meantime. At this point, should I get the VCR cleaned by someone local (like a mom and pop store) to see if that clears it?
I have talked with SouthernAdvantage and they said they think its a cleaning issue, and they will charge around $160. Do you have any suggestions for me? Thanks!
04-11-2021, 09:24 PM
Depends on where you live.
The following users thank latreche34 for this useful post: BarryTheCrab (01-28-2022)
04-11-2021, 09:28 PM
I doubt this is mere cleaning.
Belts, maybe.
For this model, drive motor is likely.
SA should know better than that. Whoever you spoke with is an idiot.
01-28-2022, 07:33 PM
BarryTheCrab BarryTheCrab is online now
If you live in southeastern Massachusetts, I have a guy. John's TV in Taunton.
Just did major work on my 7800 and it's rock solid.
In fact he just refurbed my 4800 and I'll post on that shortly.
Anyone serviced a DataVideo TBC-1000? leonroy Video Hardware Repair 3 08-26-2020 05:53 PM
What is the average cost of a JVC HR-7800 repair? videoconverter11 Video Hardware Repair 1 08-21-2016 02:00 AM
Recommended capture options with LG DR-7800? odedia Capture, Record, Transfer 7 06-18-2016 01:50 PM
How can you tell when your VCR needs to be cleaned? DeeSeven Project Planning, Workflows 9 02-06-2014 08:03 AM
