VHS maintenance/cleaning - What problems do dirty heads cause?
Hi
How much quality does dirty heads on a vcr take away from the final recorded product on dvd?...As long as a picture looks good don't worry about it? I know when I can see the picture go bad/blurry (what I will call video noise) from dirty heads that will effect the picture but should the vcr be cleaned prior to any vhs-dvd record project of length? Or do you just clean them every so many hours or only when you notice video noise? I have a vhs tape that the picture gets real grainy/blurry when watching and 5 seconds with my vhs "wave cleaning tape" clears it up quite a bit, so I guess this tape is dirty/bad?....I know I know, I shouldn't use the wave tape, it's not a typical cloth or wet tape, almost looks like some kind of plastic type of tape, I was watching that one vhs tape just a few weeks ago and had to use the wave tape a couple of times and it cleared the picture up for about 20 minutes then it gets bad again, I am going to transfer this as soon as I can figure out how to keep it clean, I don't want to transfer a dirty picture...do I need to keep the cover off the vcr and clean the heads with alcohol every 10 minutes? I can't figure any other way for a final transfer. Thanks |
1 Attachment(s)
Dirty heads generally show analog noise on screen. Speckles of "snow" would be one example. Sometimes you'll get distortion of the image, but that has to be major dirt -- and possibly damage to the head, too.
The way to properly clean a head is to lightly drop some denatured or 70-90% isopropyl alcohol on a non-cotton swab, firmly but gently press the swab against the head, and slowly turn it one rotation. Do not press too hard, you don't want to damage the ferrite heads!! Those "cleaning tapes" are largely crap, often causing damage to the heads. If it makes you feel any better, I have a similar issue on a VCR here. Sometimes it randomly displays snow stripes on screen. Cleaning the heads properly doesn't work. I have a mylar cleaning tape that I run through the deck, and it somehow fixes it temporarily. A hour or two later, the problem is back. I have no explanation for it. You're the only other person to report this issue, and I've had it for about 6 years now. The problem, the mylar cleaning tape -- they sound identical. Here's a simulated image of my annoying issue: Attachment 651 It's not a tracking error. This deck is only used a few times per year, so I've not worried about it too much. Still an aggravation, though. Too expensive to replace, too valuable to do without. |
fyi:...
This question has already been asked (and answered) here:
http://www.digitalfaq.com/forum/show...86.html?t=1486 |
Thanks for digging that up. |
...So that's a mylar cleaning tape? Now this problem is only there playing certain tapes so it makes me wonder if it's the tapes. |
Mylar ... polyester .... one of the two.
This kind of stuff drives me nuts. Contradicts itself in the same article not 5 sentences apart. Looking at the sample image at http://www.videointerchange.com/tape.htm the backmost layer is probably mylar, while the middle layer is the polyester. I knew this 10 years ago. :( Anyway... From what I can tell, it's a standard tape, but is pre-coated with a cleaning chemical of some kind, rather than oxides or particles for recording. I used to have 10 tapes like this, but am down to my last two. |
