06-17-2012, 05:14 AM
fibrecement fibrecement is offline
Hello
I have just bought a VC BR-S622E PAL S-VHS VTR Professional unit. It has a BNC out as well as a unique female S-Video output. Unlike the usual 7-pin S-Video config- this one looks like this-
Note: The twist lock ears on the outer shell denoted by a |.
* denote pin holes
The manual on-line for the JVC BR-S622E PAL S-VHS VTR lists these two items- VC-G2030U and VC-G2050U. They are a S-Video cable -male 4 pin (domestic and common) to the unique 7-pin configuration (listed above).
I'd love to track down these cables and purchase or at least find out somewhere that I can pay for such a cable to be made.
My final destination is FCP MAC. I am using a TBC (ADVC-55) that inputs S-VHS and exports FW400. I was thinking that coming out of the 7-pin SVHS- Video output would be the best, but if you have any other suggestions/solutions on how to get the best video image into my MAC I'd love to hear them.
Thanks all from Sydney, Australia.
06-18-2012, 07:27 PM
This is a rare instance where I'll quote Wikipedia (because it's actually accurate):
This is a non standard 7-pin mini-DIN connectors (this variant is called "7P"). These are used on computer equipment (PCs). A 7-pin socket accepts and is pin compatible with standard 4-pin S-Video plug.[6] The three extra sockets may be used to supply composite (CVBS) or an RGB or YPbPr video signal, or an I²C interface. The pin out usage varies between manufacturers.[6] In some implementations, the remaining pin needs to be grounded to enable the composite output (or disable the S-Video output on some of those implementations).
Have you tried using a 4-pin connector yet?
Also ...
The Canopus ADVC55 is NOT a timebase corrector! (TBC)
In fact, it has zero functionality for correcting signal timing like a TBC does. That's a myth about Canopus ADVC products.
It's just a DV converter, nothing more.
Elite Video BVP+ Cable Detached Inside Unit JasonCA Capture, Record, Transfer 1 02-01-2012 05:21 AM
Panasonic AG-1980 playing non-SVHS as SVHS? cyber-junkie Videography: Cameras, TVs and Players 15 04-21-2010 03:48 PM
Any VCR suggestions specific for 2009? via Email or PM Capture, Record, Transfer 1 09-08-2009 10:28 AM
How to split cable TV and cable internet coax for two rooms ? stoogedog Computers 6 12-05-2006 06:15 AM
