11-03-2019, 05:18 PM
FrostBite FrostBite is offline
Does anyone still work on SR-W5U units? I think a bad tape killed mine. It seems a shame to discard given how sought after they are for some users.
11-03-2019, 06:38 PM
Just for discussion, I uploaded a 30 second or so grab of what the unit is doing now. I uploaded a second video of a SR V10U for comparison. There is static every 10, 15 seconds. And the screen appears a bit darker than a 1980 or V10U.
So I guess it isn't dead dead. Just not usable.
11-04-2019, 02:42 PM
captainvic captainvic is offline
You may find Stanton TV Repair in Elmsford, NY is able to help with the JVC SR-W5U.
11-04-2019, 04:35 PM
Looks like it's not managing to lock the servo to the control track on the tape. Could be caused anything from dirty control head or corroded cable contacts to something hard to fix like a bad chip.
11-06-2019, 10:09 AM
I hope it isnt a chip. This started after I tried to back up an extremely low grade tape used to record an old college class. It locked the player up and I had take the top off to get the tape out. After that I've had this tracking issue.
Working with DV source in Avisynth? Angies_Husband Restore, Filter, Improve Quality 12 06-12-2019 07:24 PM
PAL progressive source in interlaced DVD camjac251 Restore, Filter, Improve Quality 1 01-03-2019 04:35 PM
How to put 1080i source onto Blu-ray MKV?? wigam Encode, Convert for discs 6 03-03-2018 07:59 PM
1080/50p source - what Blu-ray output? TIGER8855 Encode, Convert for discs 3 01-05-2018 04:10 PM
Do you keep your source material after capture? premiumcapture General Discussion 6 06-15-2014 07:39 AM
