04-01-2014, 02:54 PM
videonut videonut is offline
Datavideo tbc 1000 does not generate color bars. Is that normal or it needs to be repaired? TBC 100 does.
04-02-2014, 06:27 AM
The TBC-1000 (and TBC-100) -- maybe all the DataVideo TBCs -- do not generate color bars.
It does not need to be repaired, no.
And honestly, color bars are not really needed. You can use many test patterns on your own, for the TBC input, if needed.
04-02-2014, 09:24 AM
I can see a grainy color bar when turned on for a second and after that it disappears.
Thank you for advice.
Datavideo TBC-1000 discontinued? tomr Restore, Filter, Improve Quality 1 10-10-2013 09:42 PM
Best way to test DataVideo TBC-1000? cc4npg Capture, Record, Transfer 3 07-16-2011 01:41 AM
Datavideo TBC-1000 and SignVideo DR-1000 for sale [SOLD] Northpole Marketplace 2 02-15-2011 01:36 AM
DataVideo TBC-1000 vs TBC-4000 via Email or PM Restore, Filter, Improve Quality 1 03-25-2010 07:24 PM
DataVideo 100 or 1000? Which TBC version? manthing Restore, Filter, Improve Quality 4 07-13-2005 03:54 AM
