Need JVC DR-M100 inside pictures
Does anybody have pictures from inside this unit? Hope it is not to much trouble.
Looks like a cap problem or maybe something else. Loading...... Could not find ( to buy) a manual for US version. Have one for the EU version, but useless. Thank your for your time. |
common issue with those decks -
http://www.digitalfaq.com/forum/vcr-...g-jvc-dvd.html also check over on videohelp - IIRC there are several threads about it |
I got it used and looks like someone worked on this before and suspect something went wrong. I have seen in the past caps replaced with different values and tolerances, etc. That is why I need a manual or at least some pics from inside.
I read a lot of threads but I could not find at least a picture that shows the caps inside the unit. I am looking at the power supply and suspect something is wrong because I do not get power at the fan at all. Fan is good. Thanks a lot. |
Best bet is tracking down the service manual. It'll have a list of all the caps and their values. Any replacements should be rated at 105C. I personally use Panasonic branded caps in replacements. You can get them from Digikey, Mouser, etc.
Any place where they sell this manual? I found only a European version, but not the NA version. There are quite few differences, so I can not rely on that.
Thank you. |
I'll open mine. It's not in use right now.
You first. Take picture of what you see. Attach them here. Use Greenshot or Photoshop and highlight areas you need to see, and what needs to be legible. I want to do this in one shot, not several times. |
Great thanks.
Here is the list of caps that looked changed and I will take some pictures, but I do not have photoshop. c5003 150uf/200v c5103 27uf c5201 220uf c5202 c5206 c5204 1200uf c5205 1500uf c5209 2700uf c5207 4.7uf c5305 c5307 c5306 c5308 c5304 c5310 c5316 100uf 5311 2.2uf c5315 22uf c5210 c5202 18uf c3042 470uf c3020 10uf c3030 c3040 45uf c8501 100uf c8503 4.7uf c4008 10uf c4002 c4038 47uf c8202 470uf c8023 c8027 100uf c8025 4.7uf c4124 c4123 c4125 c4111 c4113 22uf c4118 c4119 c4117 c4112 c4114 100uf c8215 c8217 47uf |
6 Attachment(s)
tried to upload pics and this message came on:Your submission could not be processed because a security token was missing.
-- merged -- Here are some pictures -- merged -- Anybody? I guess not. Thank you to all of you. -- merged -- Fixed. Thanks for not sharing any picture. Have a good day. Admin can close this thread. |
Sorry about that. My camera was completely fubar. :(
I'd not used the macro for months now. Update: Unfortunately, as much as I want to help with this, I can't right now. I no longer have the photo setup that I once did, and trying to take images of "stuff" like this (not things outside) is difficult. I hope that changes in several months. |
