Quantcast Panasonic DMR ES35V U61 error - digitalFAQ Forum
07-26-2014, 09:13 PM
rumburaski rumburaski is offline
This appears to be a problem with the digital pcb under the drive unit. Does anyone know what component might have failed. The dvd drive does not make any noise. The machine does not boot properly, but powers on and off. The tray does not open. VCR part untested. Hard reset performed but it did not help. Could it be the flash chip program is corrupted? Voltage regulators? Thank you.
07-27-2014, 12:03 AM
I can't see those images. Please attach them here, to the forum.
ImageShack requires JS, and has all sorts of "lick here and wait" nonsense, and we therefore don't use it.
See also How to Properly Upload Images and Attach Files to This Site
07-27-2014, 12:23 AM
Here are some pics.
07-27-2014, 02:41 AM
The usual culprit here is bad capacitors. Sadly, none here seem to look bad. Therefore you'll have to get a meter and test the value on each.
07-27-2014, 03:51 AM
Thanks, but i ruled out dry electrolytics. I have an in circuit esr meter. All caps have low esr. Besides, the dvd was manufactured around 2006. They are old, but not that old. The worst case scenario is that the firmware is corrupted or I have a bad ic somewhere on this board. The machine appears to fail the self check. No sound from dvd rom at all. No menu. Just a brief blue screen. The machine responds only to power button. Cannot toggle between dvd and vcr. I also, ruled out bad inductors with the aid of an in-circuit LCR meter. I changed the two voltage regulators. Did not make any difference. I inspected the traces with a 40x loupe. This board is clean and quiet like a moose. It doesn't even smell bad. I did not test the oscillators yet, because the literature doesn't mention they have a high failure rate. I even refrigerated the board briefly. No change. I haven't place it in the oven yet, neither re flow it. I don't think it will make any difference, or does it. I taught myself the little skills I know. I am looking at the service manual but it doesn't look helpful. I am looking at the board. I wish it could talk to me. Just where does it hurt. Then I can mend it.
Panasonic AG-5700E vs Panasonic NV-HS1000 for transferring tapes? tsakodim Capture, Record, Transfer 8 12-31-2014 10:00 AM
Panasonic AG-1980 error F04? Useful VCR for TV tuner & signal passthrough? ALLstarGUY Video Hardware Repair 2 11-15-2012 05:48 PM
Wanted: Panasonic NV-FS 200 or Panasonic NV-HS 1000 in the UK [DONE] sandy Marketplace 1 11-07-2012 01:51 PM
Panasonic AG-1980 locks up with F03 or F04 error code? volksjager Video Hardware Repair 1 10-23-2012 08:43 AM
Can my Panasonic DMR-ES10EB record Freeview channels from my Panasonic TX-L-32G20B TV Peter_T_Ross Videography: Cameras, TVs and Players 4 09-01-2010 05:20 AM
All times are GMT -5. The time now is 08:25 AM  —  vBulletin Copyright © Jelsoft Enterprises Ltd
