10-15-2014, 09:04 AM
GreenAcres GreenAcres is offline
I picked up a DR-M10 on fleabay for $25 delivered. I replaced 9 capacitors and it seems to be working okay as far as I can tell. It did not come with a remote. I'm assuming I can't select the inputs unless I have the remote? I thought I could hook it up to my Dish Network Satellite Receiver and record via the S-Video input. But, I can't find anyway to switch the input from the tuner to the S-Video. The new My Little Pony movie is on Friday and my daughter would really like it if I could record it.
10-15-2014, 02:46 PM
you really need the correct remotes with these units.
yours should be RM-SDR009
10-15-2014, 04:09 PM
I found a RM-SDR009J. Is that the same thing?
Looking for a JVC JIG remote Tom_n_Jonna Marketplace 2 02-09-2015 01:37 AM
Using multi-account functions in WHM? Brent Web Hosting 0 09-13-2013 06:31 PM
Which remote for Panasonic VCR? monks19 Videography: Cameras, TVs and Players 1 01-01-2013 10:54 PM
Remote Trigger Canon Photo Cameras: Buying & Shooting 1 02-17-2009 12:19 AM
Remote help. MOTUfan Capture, Record, Transfer 3 05-11-2007 02:24 PM
