09-19-2014, 12:25 PM
Mejnour Mejnour is offline
Hello,
I need to remove the white plastic piece in order to change the pinch roller part. Did someone know how to remore this part safely...I succed to unfold 2 pins from the basement...but under my screwdriver there is still something that hold the white piece. Hope that I don't need to play under the tape tray...
Thanks for your answer...
Tell me if you are able to see the picture link...
https://onedrive.live.com/redir?resi...E97C8CE1%21262
The following users thank Mejnour for this useful post: tai2051 (06-28-2018)
09-19-2014, 12:38 PM
on the top pry open the 2 clips that lock into the metal shaft.
clean and lube the shaft
The following users thank volksjager for this useful post: Mejnour (09-23-2014), tai2051 (06-28-2018)
01-04-2015, 11:11 AM
Always attach images to the forum, please! (I fixed it.)
Service Manual for Panasonic NV-HS800, NV-HS1000 [DOWNLOAD] juhok Video Hardware Repair 16 07-11-2017 07:33 AM
Panasonic NV-HS1000 VCR - tape ejects, has test signal? interactive Video Hardware Repair 12 01-25-2015 09:09 AM
Panasonic AG-5700E vs Panasonic NV-HS1000 for transferring tapes? tsakodim Capture, Record, Transfer 8 12-31-2014 10:00 AM
Can I use my Panasonic NV-HS1000 as a standalone TBC? hysteriah Video Hardware Repair 2 11-07-2014 07:15 AM
Panasonic NV-HS1000 NTSC output Medusaman Capture, Record, Transfer 2 02-19-2013 05:05 PM
