Quantcast Panasonic NV-HS1000 VCR does not operate? - digitalFAQ Forum
03-14-2015, 04:11 AM
Berryscope Berryscope is offline
Hi all, I've buy this VCR recently and i've a problem with it : I can't do anything both with "keyboard" and remote. The VCR keep in standby mode. The player system seem to be ok because when i put tape in, the vcr load it and start play with picture and sound but i can't do anything else, the eject button is not functionnal. So the only solution to eject the tape is to do it manualy (i've seen the solution in the service manual). This problem looklike an "hold" function. I know the remote is communicating with vcr because when i push the transmit button the vcr send bip sound.
I've read in the service manual that are two test point to access to service display mode but i don't know where they are. I had search on the top electronic board and on the front electronic board but i haven't seen those test point.
Please i need your help.
Best regards.
Loïc from France (it explain my bad english )
03-14-2015, 04:14 AM
There is probably bad caps on the board, preventing command inputs from working.
03-15-2015, 05:23 PM
Quasipal Quasipal is offline
Or maybe the ribbon cable connecting the front buttons to the main unit has cracked.
nv-hs1000 standby problem
Service Manual for Panasonic NV-HS800, NV-HS1000 [DOWNLOAD] juhok Video Hardware Repair 16 07-11-2017 07:33 AM
How to change pinch roller on Panasonic NV-HS1000? Mejnour Video Hardware Repair 2 01-04-2015 11:11 AM
Panasonic AG-5700E vs Panasonic NV-HS1000 for transferring tapes? tsakodim Capture, Record, Transfer 8 12-31-2014 10:00 AM
Can I use my Panasonic NV-HS1000 as a standalone TBC? hysteriah Video Hardware Repair 2 11-07-2014 07:15 AM
Panasonic NV-HS1000 NTSC output Medusaman Capture, Record, Transfer 2 02-19-2013 05:05 PM
