I am trying to get a definitive answer, or at the very least a general consensus, on what is the proper power adapter for the Green/Black AVT-8710. I have no issues with the one I have but I have acquired several units without power supplies and I want to make sure to get the proper power adapters.
I know there are several topics in the forum about this subject but the information is conflicting.
I also realize the manual states 15vDC and 12vDC adapters.
The unit I have has a Jemco DDU150060, Class 2, 15vDC / 600ma adapter, center negative power adapter.
In this post,
Which AC adapter for AVT-8710?, Sanlyn states the original power adapter that came with his unit is the CUI 41-12-5000, Class 2, 12vDC, 500ma, center negative adapter. Several other units I have seen also use a 12vDC adapter.
Is the 12vDC and 15vDC confusion the same for Green/Black 8710 and the Black 8710?
Which adapters are people using for their AVT-8710, 12vDC or 15vDC?
Are there more problems with 8710 units that are utilizing a 15vDC adapter?
Can you get away with not using a Class 2 adapter?
Any insights useful and appreciated.
