01-21-2017, 04:43 AM
spacevis spacevis is offline
Hi, I have a VCR that eats tapes. Taking it apart taught me that the takeup reel does not spin when in playback mode, but it does spin when I fast-forward (or rewind). The VCR does not have an idler belt, it's just gears. I read some online guides, but most link this problem to a worn out idler belt. Does anybody know what the problem might be in this case?
02-03-2017, 09:34 PM
I wanted to reply, just so you don't think you've been ignored...
... but I have no idea. Of course, I've never been big into VCR repair. Hopefully another members will have seen this, and have some advice. Finding the service manual will probably be key.
03-07-2017, 03:31 AM
Quasipal Quasipal is offline
If you are still wanting to fix this, this is a G deck so no belts as you say. But there are moving drive gears that swing depending on mode and also a clutch. I would say that either grease has gone hard preventing something from moving or a part has become faulty such as a plastic part broken off. It is not possible to say what is wrong with yours but I do suggest you look at the official G Deck alignment video I put on YouTube (search Panasonic G deck) which will show you what is supposed to do what. G deck is solenoid driven (for mode change) then capstan motor completes the change and drives the deck. Complex decks but work well if in good order.
04-04-2017, 08:47 AM
Thank you both very much for you replies. I'll check that youtube video out and report back!
Panasonic NV-HS1000 picture (soft-sharpness) slider not working hysteriah Video Hardware Repair 10 06-21-2021 01:33 PM
6.35mm reel to reel projector? lowelljones General Discussion 1 12-13-2016 10:22 PM
Panasonic NV-HS1000: no VHS picture, audio/OSD working? amb47uk Video Hardware Repair 2 03-01-2016 11:23 PM
Panasonic NV-FS200 not working vaccastracca Video Hardware Repair 5 12-02-2014 08:30 PM
Looking for Working AG1970 or AG1980 Panasonic S-VHS VCR [FOUND] GreenAcres Marketplace 6 03-07-2014 08:03 AM
