Ribbon Cable for VCR
I need a ribbon cable to replace a broken one in a JVC HR-VP710U. Printed on the cable Sumitomo-M AWM 2896 80C VW-1. The pins are 1mm wide and about 5mm long. They are maybe .5mm or slightly less apart. Both ends have the pins exposed on the same side. The cable is 24mm wide and has 18 pins. It needs to be at least 7-8 inches long.
Where can these be purchased? |
Google search on the part number. You may find a similar one you can cut down to fit (e.g., one with more conductors).
