08-19-2018, 05:46 PM
Sillihead Sillihead is offline
Got a lot of noise on the playback so I took the lid off and cleaned the heads properly. Put the lid back on and now there is no power. I gently cleaned a small sensor by the loading mechanism and that's about it. The power button doesn't light up now. The power jack in the back... plugged my monitor into it and no power there anymore. I looked everywhere for a dummy switch.. No luck. Took the power supply out and inspected the Caps... everything looks fine. I can't figure out how this happened and what to do...
thanks
Anyone out there?
08-25-2018, 09:48 PM
How did you clean it?
Did you use non-cotton foam/chamois swabs, or did you make the mistake of using Q-tips?
Does PC have Enough Power for capture zack82 Project Planning, Workflows 6 09-25-2018 07:54 AM
LG RH1777 won't power on - What can I do to fix? via Email or PM Video Hardware Repair 1 09-30-2013 01:03 PM
Panasonic AG-1830 will not power on Just_a_hobby Video Hardware Repair 6 08-23-2013 02:16 PM
Interested in trading for a JVC BR S378U Jpass992 Marketplace 0 04-10-2013 11:45 PM
Why the JVC BR-S378U won't play mono audio tracks? jbd5010 Capture, Record, Transfer 5 04-07-2011 07:36 AM
