12-09-2018, 05:11 PM
sean.kelly sean.kelly is offline
I have failed minidv deck in JVC HR-DVS2. It takes a tape, then stars winding tape, and do not wind it to receiving roller. And then auto-turn off. If I turn on again and eject tape, it ejects but some unwinded and jammed tape should be removed manually from inside VCR. Also, I found this thing inside (look attached photo), I don't see what is it in service manual, maybe it is the root of the problem? Where it should be installed?
12-09-2018, 06:35 PM
JVC decks are infamous tape eaters for DV. The decks have a (potentially) excellent S-VHS VCR side, but the DV side is worthless. Ignore it, use it only for the VCR.
Use a DV camera for DV tape playback.
12-09-2018, 06:36 PM
I'd like to fix anyway and need help in this.
Adobe CS3/CS4/CS5 deactivated itself, repair activation fails! [SOLVED] admin Photo Processing, Scanning & Printing 13 01-27-2022 05:22 PM
JVC HR-DVS2 - Won't play MiniDV tapes, stops playing after a second or so. beef Video Hardware Repair 0 07-05-2018 03:16 PM
Minidv to PC recommendation eripey Project Planning, Workflows 11 12-19-2016 03:29 PM
How to change hostname in Linux, when cPanel or Plesk fails kpmedia Website and Server Troubleshooting 0 07-29-2012 10:30 AM
From Sony MiniDV to final DVD ravid57 Capture, Record, Transfer 29 10-01-2004 11:15 AM
