01-19-2022, 02:15 AM
enas.nikos enas.nikos is offline
Hi!
I am capturing some Hi-8 tapes with Diamond VC500 USB card. I am using a Sony CCD-TRV59E camcorder.
Can anyone help me with the following questions?
1. Does the Diamond VC500 card have internal sync?
2. What are the best "Timing" settings for the setup in VirtualDub? Are the default ones ok?
3. I read that 720x480 resolution is the one to go for capturing. Is this correct?
4. Are there any settings I need to set at the camcorder, or just proceed with normal playback?
Thanks in advance!
Best settings? (VHS/Hi8, VC500, JVC SR-VS30) uselessunderstanding Capture, Record, Transfer 17 02-12-2022 10:02 AM
Testing ATI USB 2.0 vs. Diamond VC500, has artifacts? ThumperStrauss Capture, Record, Transfer 2 06-04-2021 01:40 PM
Diamond VC500: too much of a compromise? puleddu Project Planning, Workflows 4 01-01-2019 03:46 PM
Diamond VC500 USB and VirtualDub to capture PAL? Bobban Capture, Record, Transfer 27 04-01-2017 08:02 AM
ATI AIW 7500 VE PCI vs. Diamond VC500 for LaserDisc metaleonid Capture, Record, Transfer 20 03-20-2017 02:06 PM
