Originally Posted by hodgey
Got an rca to hdmi dongle here, and it looks absolutely horrible, but it seems not all those that are sold are quite as bad, seems a bit hit and miss though.
If you desperately want a direct-to-mp4 solution, maybe something like this would work, at least you will have some idea of what you are getting.
Interesting device this ClonerAlliance Cloner Box Pro
In the video
7.21 Capture from MiniDV. It will deinterlace and capture to a full 60 fps. It cannot capture 4:3 in 720p og 1080p but adds pillarbox
14.00 capturing from VHS, but glitches, audio not good. It supports PAL but converts from 50 to 60 fps
Because of the pillarboxing, the possible glitches and bad audio I think it is not a good option for capturing analog 4:3 video. But the idea of a device that captures, deinterlaces and upscales is tempting.
Originally Posted by sanlyn
It's no news to us that internet players can't handle interlace, can't handle telecine, don't resize well, and can't handle non-square formats. So for 4:3 originals, folks like YouTube with their pretty dumb online players require that you get your capture into progressive double-frame-rate mode with QTGMC, resize to 960x720 (Avisynth's spline64 algorithm and nnedi3-rpow2 do a neat job of upsizing), then add side pillars to make the 16:9 1280x720 frame they usually require. YouTube will resize and down-sample the bitrate for several choice sizes before mounting, so do a clean job (because they'll use the quickest and dirtiest methods they can and certainly won't make any improvements for you).
I have uploaded 960x720 to youtube, with no side pillars. Like this
https://www.youtube.com/watch?v=HEI9BFXmeNc
You mention double-frame-rate. Should I use the double framerate generated by QTGMC? Right now I add the SelectEven() command to get back to 25 fps.
Originally Posted by Bogilein
If you use a dvd recorder in passthrough mode for the jitter correction and as tbc replacement (like many of us do  ) there is a analog to digital conversation on the input signal and if you use the S-Video/Composite connectors for the outputs, there will be a digital to analog conversation. When you use a dvd-recorder with hdmi output you can save this digital to analog conversation. You can grab the digital file. The Blackmagic card was the only one who could capture this file in YUV2 uncompressd via the HDMI Input of the card. There is no upscaling or deinterlacing. You only grab the digital file in 720x576i resolution. Testing has only made with PAL equipment.
I have a Panasonic DMR-EX77 with HDMI output.
Right now I capture analog like this VCR > ES15 > Hauppauge USB 2 live > PC
I understand a HDMI capture workflow would then be
VCR > EX77 > Blackmagic > PC
This workflow seems to be tested and recommended by some in the internet. But as you say no upscaling or deinterlacing. So not an advantage unless the quality is better.
A stand alone S-VHS/Scart to HDMI converter with integrated upscaling and deinterlacing would be nice. But the conclusion seems to be that these HDMI converter/scalers are just not good enough quality.
