Sony VRD-MC3 created DVD impossible to rip?
I was capturing a VHS tape using a Samsung VCR hooked up through composite cables to a Sony VRD-MC3 DVD Recorder. I have captured VHS tapes through this exact method before with great success. Something I often do after the DVD burning is complete is create an ISO of the disc to burn exact duplicates with that can be handed out.
This time seemed no different, except that there was a portion of the tape I wanted to cut out, so for the first time I used the "pause" function on the recorded, halting recording just long enough to fast forward through the unwanted bit. I continued recording after that point, and everything seemed to go fine. Finalized the disc, it played back perfectly fine in my DVD player with no issue. However, when I try to rip the DVD to an ISO, I keep running into the same issue. I have tried to rip the DVD in 2 different applications, PowerISO and ImgBurn, and the same problem happens. First, it refused to capture to an ISO, saying it must be saved as a BIN/CUE because it claims the disc is multi-session - despite disc info showing only 1 session. If I go ahead and agree to a BIN/CUE, at about 35%, I will get the error, "Data Error: Cyclic Redundancy Check". If I tell it to retry, same error, tell it to ignore, the process hangs and the ETA extends to days and beyond before I give up and cancel the process. The disc is clean, I have wiped it down multiple times. I would like to not have to reburn another disc, certainly not if I will run into the same problem. The disc still plays fine in DVD players, my computer just doesn't like it. I suspect it might have to do with my pausing recording (would it register that as different sessions? Then why does the disc info still say one session...?) Is there a way to make my computer create an ISO or BIN/CUE despite the data error? Or will I have to retry - or use a different method entirely? I do have access to a Digital8 camcorder, and appropriate cables to use it as a capture cam. I would hope I don't have to get into such an involved process, though. |
1. Sony recorders are lousy quality. Nonetheless, on the the question...
2. Use DVD Decryper to decompile in IFO mode. See this guide to get started: http://www.digitalFAQ.com/guides/vid...d-recorder.htm I doubt this is an unrippable disc. And generally, when that happens, it's because the disc is bad (coaster). |
1 Attachment(s)
I followed your advice and tried to rip the disc using DVD Decrypter in IFO mode. Unfortunately it gave me the same result, just more detailed an error message, which I've attached below. |
The disc is bad.
Nero DiscSpeed would show yet more details on disc condition. Download: http://www.digitalfaq.com/forum/medi...a-quality.html What did you use? Brand, x speed? See also http://www.digitalFAQ.com/reviews/dvd-media.htm Slight chance the disc is marginal, but the drive isn't great, with net result still being unreadable disc. |
1 Attachment(s)
I used a Memorex DVD-R, 4x speed (Part #: 3202 5510 if that helps). Came from a pack of 4. The other 2 I've used up to now burned fine, this one clearly didn't. Worried about my last disc now, haha. I guess at this point my best solution would be to recapture the VHS using my Digital8 Handycam and a Firewire port? Then I can just work with digital files instead of having to rely on DVD media. Could probably make a much better quality DVD then the Sony spat out as well. |
NTSC or PAL?
If NTSC, you'll trade DV choma loss for MPEG macroblocks. DVD still worse. If PAL, definite upgrade in method. |
Would love to get a higher end capturing setup in the future, but I don't have the disposable income to get those sorts of decks at the time. |
