Capturing damaged tape, curled VHS-C?
I found a damaged s-vhsc tape I want to capture.
Tape was a standard vhsc perforated to used as s-vhsc. It's LP also :eek: Physically the tape appears a little curled for about 1mm to the upper edge. Trying to play (JVC S5800 pal) directly on tv is a disaster, with a large noisy bw speckled band in the upper side. The strange thing is that if I pause, the image is quite good. I tried to disable digital tracking and fine tune, the upper side improve, but begin to appear white dots everywhere. I didn't try to capture directly on mxo2, watching the preview is useless even if it doesn't lose frames. I got an es10 and two DVK-100 (to be sure it works). So, my actual workflow (PAL) is: JVC S5800 > ES10 > DVK-100 > mxo2 mini At a first test in preview, there is a big improvement, but I can see a vertical flickering. Some frame/movies later. |
I tested the same workflow with a sony HF950 betamax. I got the same vertical flickering.
Removing the es10 from the chain, it desapear. Bad caps? I have to get another es10/15. |
It seems the same problem here in the second sample:
http://www.digitalfaq.com/forum/vide...ommon-vhs.html |
Interesting thread on videohelp:
https://forum.videohelp.com/threads/...ndrome-Any-Fix The tape of my s-vhsc is in similar conditions. |
