-   -   Wide transparent bars seen throughout my transfers? (https://www.digitalfaq.com/forum/video-capture/10448-wide-transparent-bars.html)
PaulL 03-21-2020 01:11 PM
1 Attachment(s)
For the first time since the mid 2000's, i've gotten back into transfering VHS onto DVD.
Since my Pioneer DVR-640H DVD recorder (connected to my Panasonic PV-V4520-K VHS deck) still works like it should, I'm using it to record my
VHS transfers.
This time around, I'm transfering movies (ones that never got a digital release of any kind) from retail tapes for reviewing purposes.
The problem i'm having now with those rips that I didn't have before with just regular tapes is that i'm getting 2 wide trasparent bars (vertical and horizontal) crossed together throughout the recording.
I've attached a sample video of it.
Is it the way i've plugged the wires from the DVD recorder/VHS/TV that's causing it? Is it my VHS player showing fatigue? In need of a good cleanup?
Anyone had this problem and found a solution?
Your help is much appreciated.
dpalomaki 03-21-2020 05:04 PM
Are to home recordings have the ghost as well? or is it restricted to commercial tapes?
Looks a bit like a pulse-cross ghost. If this is only on commercial tapes it might be an artifact of copy protection.
What are the details of your connections? Are you using a TBC?
themaster1 03-22-2020 04:05 AM
Looks like a ground loop to me, see here: https://bavc.github.io/avaa/artifacts/ac_beat.html
Solution: powering all devices in the video system using one source of electricity with all outlets serving power with minimal difference in ground potential
msgohan 03-24-2020 10:28 AM
Yeah, we're definitely looking at a moving ghost of horizontal & vertical sync. Not ground loop.
It's like the artifact in this thread, but stable instead of diagonally skewed: https://forum.videohelp.com/threads/...=1#post2573681
Do you have anything else connected to the VCR or DVD recorder?
PaulL 03-25-2020 10:58 AM
4 Attachment(s)
No TBC.
I was hoping it was a ground loop like he described because I had connected the DVD recorder on a seperate wall outlet but the bars
still showed.
In fact, I just noticed it doesn't show when its only the VCR player that's on and the tape plays fine without the bars, it's when I start up the DVD recorder for a recording that the bars show up.
The setup on each devices:
TV = Video 1
VCR = Channel 3
DVD Recorder = Channel 3
I added pictures to show the chords in the back of all 3 devices to see if maybe there's a connection problem there? if you need better pictures lemme know. :)
msgohan 03-25-2020 01:23 PM
Disconnect all of the RF coaxial cables.
Connect RCA (yellow, white, red) output from VCR to DVD recorder. Connect RCA output from DVD recorder to TV.
PaulL 03-25-2020 07:09 PM
FIXED! :congrats:
I can't believe all it took was removing the RF coaxial cables.
For some reason, I thought they were important to plug in when I first set the whole thing up.
msgohan: :salute:
Thanks a bunch for the help everyone. :)
