PAL60 capture, intermittent greenish tint?
4 Attachment(s)
Hello,
This is my first post here, and I'm in need of some help. I've recently purchased an Elgato Video Capture usb device, one that accepts PAL60. I'm still getting the hang of it, so I apologize if this has been answered already, but honestly I couldn't find a similar situation. I'm using a simple PAL vcr, no tbc. It's connected with composite cables, with a scart adapter on the vcr side. Still, I'm pleased with the results, so far, it gets the job done. However, when capturing NTSC tapes, in PAL60 format, there's an intermittent, soft greenish tint. I don't think it's Macrovision, at least it doesn't look like it, and I believe the tapes in question are too old for it. This doesn't happen when I connect the vcr to my tv, so I guess that rules out both the vcr and the tapes. It does happen with both Elgato's software and VirtualDub, which I prefer. Naturally this doesn't happen with PAL tapes, only NTSC ones. Here are a couple of caps, from the same scene, illustrating how this changes from one frame to the next. Normal: Attachment 11484 Green: Attachment 11485 This is especially noticeable in skin tones. In other scenes, with strong reds and oranges, I get purplish horizontal lines, equally intermittent. Normal: Attachment 11486 Lines: Attachment 11487 Does anyone have any ideas, maybe some VirtualDub filter...? Is there still hope to make it work with this hardware? Thanks in advance :) |
Composite isn't helping matters. It's a hardware workflow problem. You need TBC, it's not optional for capturing. I just linked this for another poster: http://www.digitalFAQ.com/editorials...g-workflow.htm Especially this part: Quote:
Thanks for your reply.
Yeah, unfortunately, given the tapes I want to capture, getting a tbc is out of the question, I really don't want to spend the money, and I wouldn't even know where to get one, or which one to get. Like I mentioned, though, when it comes to PAL tapes I'm finding the result pretty satisfactory, so I guess I can consider a tbc relatively optional in that regard, given the circumstances. Unfortunately the same doesn't seem to apply to PAL60... By the way, and I'm sorry if it's a stupid question, but... composite isn't helping, even though it's all I have, but a scart adapter with S-Video output wouldn't make any difference, would it? Considering the vcr itself doesn't have an S-Video output, and the tape isn't an S-Video one... |
Using a SCART adapter with S-Video output would actually be worse in this case. An additional crosstalk artifact would be added.
In addition to the color issues, we can see lack of line TBC in the screenshots posted. The borders of the image should be straight; yours are bent and wavy. Everything within the image will also be affected, but in these still shots without any columns it isn't obvious. I suggest hunting for info on which DVD recorders can function decently as passthrough TBC while supporting PAL60: https://forum.videohelp.com/threads/...=1#post2574731 |
The lines you are seeing is leftover color signal that the capture device has not been able to filter out. I'm guessing the Elgato uses the conexant chips similar to the Diamond VC500 and hauppauge capture dongles, which are not very good at separating the color and brigtness from a composite signal. I second msgohans suggestion. |
