I've used a BlackMagic Design Intensity Pro card to capture HDMI stream outputs from a laptop, BD player, and from a FIOS set top box with both Win 10 and Win 7. I mainly use the included MediaExpress software the MJPEG file format, but it also supports uncompressed formats. It supports capture from a number of NLEs as well, both SD and HD, NTSC and PAL. Be aware it requires exact format selection to capture successfully; e.g., 1080i60i is not the same as 1080i59.94.
The Intensity series also supports analog capture: composite, s-video, and component, (subject to some significant limitations).
And I've have used its HDMI output to drive a TV set.
