-   -   VHS-C horizontal lines/distortion, what's wrong? (https://www.digitalfaq.com/forum/video-capture/10623-vhs-horizontal-lines.html)
Richard24 05-14-2020 05:22 AM
Hello,
I have been successfully importing VHS & VHS C tapes for family archival purposes. I am struggling with two tapes.
The physical condition of the cassette is good and the tape looks clean, non-sticky, without creases or shedding. These tapes were stored with a member of my family in the same box with the same conditions as the rest of the tapes.
While most import perfectly as I would like them, these tapes have horizontal lines across the entire image, what can I do to fix it?
Capture Devices:
Panasonic NV-SD430
Panansonic DMR - ES10
Pinnacle Dazzle USB Capture
Pinnacle Studio 23 / Adobe Premiere Pro
Please see this example I have uploaded to YouTube so that you can see what is happening. https://youtu.be/Qk1fJ5n6UHY
I really appreciate your help in answering this.
hodgey 05-14-2020 05:53 AM
It looks a lot like the effect you get when playing a Super-VHS recording in a normal VHS player. Even if it's not a SVHS cassette later models of SVHS VCRs and camcorders could record in Super-VHS at slightly reduced quality on normal VHS cassettes (called SVHS-ET). In that case you would need a SVHS VCR (or camcorder) to play them back properly. Some late 90s/early 2000s standard VHS VCRs could play back SVHS at reduced quality, labelled as SQPB, but you need a proper SVHS VCR to get the full quality out of SVHS recordings.
Black lines like this can be a result of other things like worn heads or certain other faults with a playback or recording VCR. That seems less likely though since given that you state that many recordings play back fine, and it's usually not quite this severe.
latreche34 05-14-2020 12:45 PM
Certainly a S-VHS tape or S-VHS ET, The black stripes are clipping of the luma bandwidth since VHS has a limited bandwidth.
Richard24 05-15-2020 08:40 AM
Thank you so much for your assistance.
