Quantcast Trouble with X1900 AIW - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Capture, Record, Transfer
06-21-2007, 12:09 PM
Tom_n_Jonna Tom_n_Jonna is offline
Hi guys...need some help.
I've been searching the net and have found nothing but conflicting info.
I picked up an ATI x1900 AIW and installed Catalyst 7.1, then MMC 9.15 and my system started uncontrolably rebooting itself. It would start, get into windows XP, then shut itself down again.
I have an ASUS board using an AMD X2 5200+.
Any suggestions besides getting another board? Which versions of Catalyst and MMC can I safely use and still leverage the capabilities of the board?
Thanks!
__________________
Cheers...Tom
06-21-2007, 12:54 PM
wheezer210 wheezer210 is offline
I had an AIW x800xt for a LONG time, and I always used the 5.10 drivers and the MMC 9.06. (never updated even for gaming)
No matter what I did, if I used any other driver combo my pc crashed like a mofo but using these it aways worked.
here are the 5.10:
http://support.ati.com/ics/support/d...estionID=20767
here is the mmc 9.06:
good luck I know what a frustrating pain in the arse driver combinations can be.
06-21-2007, 08:51 PM
Thanks Wheezer...
I checked these out....seems 5.10 does not have native x1900 support. Not sure how that will work, but am desparate enough to try it anyway at this point. More to come.
Cheers...
__________________
Cheers...Tom
Question concerning tv problem trouble shooting stoogedog Home Entertainment and Videography 2 08-03-2006 03:20 PM
MMC Capture settings for X1900 PCI Expres groovy Capture, Record, Transfer 7 05-03-2006 02:21 AM
Trouble w/ TBC...HELP! Tom_n_Jonna Restore, Filter, Improve Quality 3 01-21-2006 12:39 AM
Having some trouble... Daniel Capture, Record, Transfer 9 06-06-2005 10:25 AM
Having login trouble? (IE5,IE6) Here’s the fix... admin General Discussion 0 04-19-2004 03:32 PM
All times are GMT -5. The time now is 11:22 AM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
