07-10-2020, 02:20 PM
digicube digicube is offline
It plays betacam sp fine but display vertical lines and bad color with digital betacam. I'm guessing bad caps on the PCB that handles digibeta. I can't find a service manual for it.
https://drive.google.com/file/d/1rpB...ew?usp=sharing
07-20-2021, 01:09 PM
BrandonSmoothps BrandonSmoothps is offline
Did you ever find a fix for this? I am experiencing a similar issue
07-20-2021, 02:03 PM
No but I'm guessing it's a bad Digibeta board that needs replacement or a component on the board replaced.
Weird vertical lines on VHS capture? Specific Capture, Record, Transfer 5 09-03-2018 05:23 AM
Vertical lines on PAL VHS transfer? thestarswitcher Restore, Filter, Improve Quality 6 07-29-2018 07:09 PM
Need help with blue vertical lines max_cady Restore, Filter, Improve Quality 3 05-03-2011 04:24 AM
