07-25-2020, 07:48 AM
LilGoatholes LilGoatholes is offline
Hi,
I'm digitizing some old VHS tapes. I'm in Europe (PAL). My setup is as follows: Philips VR-1000, TBC 3000, Hauppauge USB Live 2.
I've been able to capture almost all tapes without any hassle, but i'm struggling with the last one. When I play it using the Philips VR-1000, the picture jumps up and down with both TBC ON and TBC OFF (see attachment).
I also have an old AKAI consumer grade VCR, which plays the tape quite well (picture is stable), but it doesn't have line TBC and DNR. What could be the reason of this problem and what options do I have to proceed?
1. Repair or tweak the VR-1000 somehow, so it would play the tape better?
2. Capture using consumer grade VCR and run the signal through Panasonic ES10/ES15, then to TBC 3000?
3. Re-record the tape using VR-1000 and then capture?
4. Get another S-VHS VCR? Perhaps Panasonic one?
5. Something else?
Any help you could provide would be much appreciated.
Tom from Czech republic
Mitsubishi HD-HS2000U problem with playback PontiacKendall Capture, Record, Transfer 2 07-20-2020 01:07 AM
VHS Playback problem (snow) airamcruz Video Hardware Repair 8 05-17-2020 05:28 AM
AVI capture problem! Huffyuv glitched playback? rocko Capture, Record, Transfer 14 03-17-2017 07:33 PM
Panasonic NV-HD620 LP/EP playback problem? nesburf Video Hardware Repair 10 03-07-2017 09:11 PM
Panasonic NV-FS200 playback problem zeroprobe Video Hardware Repair 13 12-01-2010 11:07 AM
