All,
I’d like to kick-off a video capture project, but there is a snag…
… I have a number of camcorder VHS-C tapes which have been recorded in NTSC, but I am resident in the United Kingdom. That means that pretty much all of the commonly available VCRs are PAL.
From reading round the excellent FAQs on this site, I understand that having separate VCRs to capture NTSC or PAL tapes is the best way to go. However, as I am in the UK, importing an NTSC VCR is likely to be a problem.
For the purposes of practicality, it’s likely to mean that I am going to need a machine that can produce a “true” NTSC 3.58 signal (in addition to its usually used modes), before passing this through a TBC such as the Panasonic DM-Exx series and then capture.
I would like to capture the video in a good quality as possible in an uncompressed format, before cleaning the video up with filters etc.
Am I completely barking up the wrong tree? A couple of questions that I have after looking at what’s available on the big auction site have sprung to mind:
(i) Is composite video definitely what is required here when using an outboard TBC?
(ii) I’ve noticed a number of machines that can output an NTSC 4.43 signal (as opposed to a NTSC Playback on Pal TV), could this type of signal be fed to a TBC before capture?
(iii) Do I need to bite the bullet and import a “true” NTSC machine from the US or elsewhere?
I am not opposed to doing some servicing work (I have the equipment) and as mentioned, I would like if possible to obtain as high quality as possible (I’ve obtained and repaired a drum scanner from still image digitisation work previously).
Any tips, pointers, laughs, suggestions would be welcome – LordSmurf or other regulars, do you have any ideas?
Or, if there is anyone in the UK that does have a machine that can produce NTS 3.58 that is surplus to requirements, I would be interested to know!
Thanks for reading,
J.
