You always need frame TBC, period. Regardless of line/field (internal VCR) TBC in use.
- external/framesync TBC cleans the signal
- internal/line TBC cleans the image
For quality transfers, you need both.
That exact model VCR is ancient, not suggested. That unit doesn't have a TBC, according to what I've read. That was an industrial VCR, with many limitations.
Yes, several good USB capture cards work well with Win10, but note that none are sold new. There are excellent USB cards that worked well in Win7, and the drivers still install wit Win8/10. Certain ATI clones (not all), certain Pinnacles (not all). PAL vs. NTSC (or both) also matters, to make sure you're pairing the best card with the workflow. Sometimes the VCR and TBC in use need to be known as well, to prevent known workflow devices conflicts.
