09-13-2020, 11:44 AM
DaveT DaveT is offline
Trying to Capture Old VHS tapes
After reading lots of Posts about Capture.
I want to try S-VHS out of VCR into
Panasonic DMR-ES15 OUT into VC500 S VHS in
the USB 2.0 into Win 10 Computer.
The Original VHS Tapes Are not S-VHS but
My reading was that using the S-VHS Cables would be Best.
How do I Post a short Sample of my test results to the Forum ?
Thanks for your Help DaveT
09-13-2020, 11:52 AM
See http://www.digitalfaq.com/forum/news...ly-upload.html
VCR > ES15 > VC500 can work
Not will work, can work.
- That VC500 can be a variable card. Some have issues, some not.
- ES15 is not a TBC, but can suffice as minimalist stand-in for source types of SP homemade sources in perfect condition.
- Win10 often fights you
s-video is ideal.
Composite in itself isn't bad, but rather the device use of composite can be (and often is).
09-13-2020, 11:43 PM
Hello
Thanks for the Reply.
I Read the Upload Info.
Is there an Easy way to Cut
A Short clip from A longer AVI file
For Posting ?
DaveT
VirtualDub capture with VC500? ferggue Capture, Record, Transfer 19 01-19-2022 02:32 AM
VC500 capture problems in Windows? Nunkin Capture, Record, Transfer 10 09-02-2020 02:00 AM
Diamond VC500 USB and VirtualDub to capture PAL? Bobban Capture, Record, Transfer 27 04-01-2017 08:02 AM
Diamond VC500 won't capture with VirtualDub and Win10 SoManyTapes Capture, Record, Transfer 5 01-03-2017 07:17 AM
VHS capture to AVI with VC500 -- thoughts? jmt0 Capture, Record, Transfer 15 01-14-2014 08:57 AM
